Draining power steering fluid
  • GuardianAngel
12 years 2 months ago #124261 by GuardianAngel
Draining power steering fluid was created by GuardianAngel
I have had a Google around but can't find an answer, so...
I need to remove the power steering hoses to get access to the back of the front cross member as it needs welding up. So as the title states, how do I drain the power steering fluid from the system?
12 years 2 months ago #124294 by facade
I'd undo the pipes that have to come off and let it run out into a bucket. B)
You could use an oil syringe to suck the reservoir empty if you like.
Don't run the engine without fluid in the pump.
When you fill it back up, turn the steering lock to lock a few times at tickover to purge any air.
The following user(s) said Thank You: GuardianAngel
  • GuardianAngel
12 years 2 months ago #124308 by GuardianAngel
Replied by GuardianAngel on topic Draining power steering fluid
facade wrote: I'd undo the pipes that have to come off and let it run out into a bucket. B)
Cheers :)
Time to create page: 0.084 seconds
