Which replacement back box?
  • tommyguns
12 years 1 month ago #126567 by tommyguns
Replied by tommyguns on topic Which replacement back box?
ive had my backbox off when replacing the entire system for MOT. but the standard one sounds shite =/
looking at a cherrybomb backbox, any chance of a video back in black?
  • Back in Black
12 years 1 month ago #126569 by Back in Black
Replied by Back in Black on topic Which replacement back box?
Hi TommyGuns,
I'll try and video it at lunch time (rain permitting) and post the video.
Docmartin put me on to the place to get it from - I went through their ebay shop, and got the 38mm-45mm version, the item number is 160565309732, very fast service :)
  • Back in Black
12 years 1 month ago #126679 by Back in Black
Hi TommyGuns
I've videod the exhaust, but can't load the clip onto the site!!
If you pm me you email address I can email it to you?
  • Dyl
12 years 1 month ago #126693 by Dyl
Replied by Dyl on topic Which replacement back box?
My back box is blowing. Just popped in to my local exhaust centre and they want £160 to replace the back box and short middle link pipe.
Seems a lot to me bearing in mind the back box is £38 from Eurocarparts.
Are they easy to fit?
  • mickt
12 years 1 month ago #126710 by mickt
Replied by mickt on topic Which replacement back box?
The middle and back box bolt together on a flange but if you are going to replace both then just unbolt the middle to front join and cut the other two apart as these back bolts will probably be in a mess and need cutting/chiselling/grinding off. You can get a fitting kit for the middle to back box connection which consists of the metal ring seal and two new rubber hangers. The middle to front connection has two large springs around the bolts as the joint is designed to flex as required. The original Suziki back box came with a heat shield on the upper surface which normally rots away. The replacements do not have this. Whether it is necessary is open to discussion. When I replaced mine the shield was mostly intact so I reattached it to the new box by welding bolts to the box, fitting the shield and then adding nuts and welding them in place. Probably not needed but I like to try and keep the cars as the factory intended.
