Servicing Help - New Jimny
  • Dyl
13 Sep 2014 19:58 #124014 by Dyl
Servicing Help - New Jimny was created by Dyl
So I just bought my first ever Jimny. Has low mileage of 52,000 on a 51 plate but there is no real service history for the last few years.
I'm no mechanic, I think I can change the oil, plugs, air and oil filter no problem, but would you advise it requires more service attention than these basics?
Not sure if I should take it to a local garage to be serviced, but unsure exactly what they would do above and beyond what I just mentioned.
Also, what mileage should the cam belt be changed at?
If anyone can advise on what things may need checking or changing then your help would be appreciated.
  • Statey
13 Sep 2014 21:44 #124027 by Statey
Replied by Statey on topic Servicing Help - New Jimny
I'm no pro but I replaced the timing belt and both drive belts following the workshop manual for Jimnys :)
Actually was really good to work on everything has space to worn and can be removed with a socket set :)
  • jtayl153
14 Sep 2014 07:00 - 14 Sep 2014 07:03 #124035 by jtayl153
Replied by jtayl153 on topic Servicing Help - New Jimny
If I were you I'd go all out:
Oil & filter
Air filter (I recommend K&N performance filter)
Spark Plugs
Diff oil & plugs
Gearbox oil and plugs
Transfer case oil and plugs
A lot of Jimnys I've worked on have knacked plugs for diffs, gearbox and t-case. Most had to have a nut welded on to remove. So I'd recommend ordering some new plugs to swap out when you change the oil
Id also check all your belts for wear as well as the bearings. Bearings can be checked by jacking up a wheel and trying to wobble it vertically. If there is movement, bearings can be worn. Also, excess grease on the back of the swivel hubs is a sign of worn bearings too
I'd also do a radiator flush. I do one every 6 months as I do a few muddy crossings and the coolant can get a bit murky
All up that'll only cost maybe 100 pounds if you play your cards right. If you want your Jimny to last, change the oil and filter every 5000kms (2500miles)
Last edit: 14 Sep 2014 07:03 by jtayl153.
17 Sep 2014 22:57 #124418 by auchenblae
jtayl153 wrote: If I were you I'd go all out:
Unless you are doing offroading change the oil at the Suzuki recomended intervals. I took our last Jimny to 100,000 miles and changing the oil at 9,000 miles with no lubrication problems at all.
Unless jtay can provide some quantatative evidence to dispute this.
eddie
24 Swift Ultra ALLGRIP
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
18 Sep 2014 16:31 #124454 by facade
Replied by facade on topic Servicing Help - New Jimny
In The Olden Days you used to change the oil frequently, nowadays the engine design and oil composition means that the oil will lubricate well for longer, but changing the oil more often is good practice, I'd change the oil but change the filter every other change, unless the oil that came out was dirty, as that few seconds with no oil pressure when you change the filter probably causes some wear.
If the car is a hardtop 51 plate it wont have a cambelt.
Time to create page: 0.128 seconds
