steering box adjustment
- Thank you received: 77
12 Sep 2014 10:51 #123932
by robs5230
standard jimny - for now
steering box adjustment was created by robs5230
hi. can the steering box be adjusted on the jimny ? i have a 99 model that has a slight bit of play in the steering. i'd like to have a look at it before mot time at the end of the month.
cheers rob
cheers rob
- Docmartin4x4
12 Sep 2014 15:38 #123948
by Docmartin4x4
Replied by Docmartin4x4 on topic steering box adjustment
On mine (06) there is an adjuster on the top, where you undo the lock nut turn the screw thread and retighten the lock nut. Just be careful that you dont over tighten as there should be a little play, otherwise you will do serious damage to the box.
Mart
Mart
12 Sep 2014 15:41 #123950
by facade
Replied by facade on topic steering box adjustment
I've not looked, but the manual shows a lock-nutted adjuster bolt on top of the steering box.
Be careful adjusting it, as the wear is in the straight ahead position, if you take it all out the steering will jam when you go to full lock.
You are allowed 75mm movement at the steering wheel rim without anything happening at the wheels in the straight ahead position.
This is as huge as it sounds, if you have more than that now start looking for shot ball joints and a new steering box. :ohmy:
Time to create page: 0.076 seconds
