vibration from rear only when hot
  • S Mark
09 Sep 2014 19:14 #123739 by S Mark
vibration from rear only when hot was created by S Mark
Yes another jimny with another vibration.
In the last 6 months I have fitted a 4.5" lift and king pin bearings amung other things, I have been driving the jimny about absolutely fine but no motorway driving, at the weekend I decide to go laining a bit further out so jumped on the motorway and sat at 55-60 all was fine for five minutes then I start getting vibration from the rear and it only gets worse until you drop below 40 ish, no change when the clutch is down or in neural. So I stop for 20 minutes and have a quick look to find nothing obvious and carry on under 40 mph. Do an hour of slow 4x4ing a river crossing and then back on the motorway at 55ish and its fine again for 5 minutes then the judder/vibration comes back. I have my suspicions it might be the propshaft or the rear diff? Has anyone come across this before? Any of your thoughts would be grateful.
  • darthloachie
09 Sep 2014 19:53 #123741 by darthloachie
Replied by darthloachie on topic vibration from rear only when hot
sounds like the front bearing ( where the prop fits) on the rear diff - we had a similar problem
  • S Mark
09 Sep 2014 20:05 #123744 by S Mark
Replied by S Mark on topic vibration from rear only when hot
Thanks for the quick reply, that what I had in mind in the past I have broke the transfer box rear mount so all its weight would have been on that bearing. I have no play in it but think I will have to take the diff out. Will it obvious once removed or will it be best to send it away do you think?
  • steffan
09 Sep 2014 20:27 #123747 by steffan
Replied by steffan on topic vibration from rear only when hot
If you don't know by now send it away and let somebody else do it its not as simple as unbolt and swap bolt back up there's preload and backlash that needs to be set
  • S Mark
09 Sep 2014 20:38 #123749 by S Mark
Well I don't no yet but there's always time to learn. I have a 2nd hand diff to put in its place might be just as bad if not worse knowing my luck but at leas I can carry on 4x4ing while I do a bit of research on rear diff set-up ect. I assume it's adjusted with a crush washer/tube.
  • steffan
09 Sep 2014 21:08 #123754 by steffan
No idea to be honest pal I thought it was set with the rings on the side gears and locked in place with a little metal bracket but I could be wrong that's exactly why I would send away
Time to create page: 0.106 seconds
