Scare behind front wheel arch liners
  • mickt
07 Sep 2014 18:36 #123551 by mickt
As mentioned in previous topics here my Jimny is due its mot and, having just about sorted the rear ends tin worm, I decided to remove the front wheel arch liners just to make sure all was well as the rest of the structure upfront looked like it had faired well against the creeping cancer that is rust. Mistake big time! The box section that runs across the front and contains the mounting structure for the body to chassis mounting bolts had corroded at the rear of the box and behind the headlamps. At this point the metal is three thicknesses and is going to prove to be a challenge to repair. The problem is the liner that is there to protect these vulnerable areas unfortunately seems to do the opposite at this area. I take it that it is a common rot point on the Jimny?
  • GuardianAngel
07 Sep 2014 19:41 #123555 by GuardianAngel
Replied by GuardianAngel on topic Re:Scare behind front wheel arch liners
Yep mine is knackered behind there as well. The liners are a hindrance to be honest. I am tempted to cut the box section out and fab something up much stronger and less likely to rust. It will be a bolt on job at first until I can find someone to weld it in for me.
07 Sep 2014 20:51 #123566 by funkyjimny
Yes I threw my liners away on my car 9 years ago when it was 12 months old, I've had a few other jimnys over the years and they have all rotted there but this one that has no liners in has been fine.
Gary
The following user(s) said Thank You: GuardianAngel
07 Sep 2014 21:45 #123580 by kirkynut
funkyjimny wrote: Yes I threw my liners away on my car 9 years ago when it was 12 months old, I've had a few other jimnys over the years and they have all rotted there but this one that has no liners in has been fine.
Gary
This is definitely the way to go. I took mine off and had the rust cut out and new metal let in and it's been good since it's been able to air and dry.
  • mickt
08 Sep 2014 10:22 #123605 by mickt
Replied by mickt on topic Scare behind front wheel arch liners
Mystic Rich: I hope you replaced the rot with some sort of structure as without it I would have thought the body mounting would be undermined and a possible fail point!
  • mickt
08 Sep 2014 10:24 #123606 by mickt
Oops, I have just noticed your attachment, see what you mean!!
Time to create page: 0.106 seconds
