speedo problem
- Lorry
12 years 2 months ago #123535
by Lorry
speedo problem was created by Lorry
Hi my speedo sometimes works but not showing true speed and other times doesn't can anyone advise on what the problem might be?
Thanks in advance for any help Lorry
- Basketcase
12 years 2 months ago #123567
by Basketcase
Replied by Basketcase on topic speedo problem
Loose connection somewhere in the clocks, mine does it just give it a whack and it'll spring into life
- funkyjimny
- Moderator
- 2004 jimny soft top, factory hardtop, ARB bumper
- Thank you received: 56
12 years 2 months ago - 12 years 2 months ago #123568
by funkyjimny
Replied by funkyjimny on topic speedo problem
First thing I would check is the connections on the speedo sensor on the transfer box and any other connections in those wires through to the clocks in the car. If the wires are ok see if you can borrow a speedo sensor from a friend to see if that resolves the problem .
Gary
Gary
Last edit: 12 years 2 months ago by funkyjimny.
- Lorry
12 years 2 months ago #123594
by Lorry
Replied by Lorry on topic speedo problem
Thanks for answering I will check it out today.
cheers Lorry
cheers Lorry
Time to create page: 0.083 seconds
