Arm bushes
  • Vinnie
07 Sep 2014 10:25 #123519 by Vinnie
Arm bushes was created by Vinnie
When fitting a lift kit I've removed the arms for a tidy up ie paint and noticed this don't look right lol I'm assuming new ones need to be pressed in ? Or are they a knock in type ? Obviously these are the original ones so well seized in.Shall I fit standard ones or the poly bushes ? Has anyone got anything ?
Cheers Vinnie
  • gaz3359
07 Sep 2014 11:27 #123523 by gaz3359
Replied by gaz3359 on topic Arm bushes
Well shot those,size lift have you gone for ? May aswell fit caster correction bushes can get them from bits4vits for about 80 quid delivered.ive got a set to go in
  • Vinnie
07 Sep 2014 11:31 #123526 by Vinnie
Replied by Vinnie on topic Arm bushes
gaz3359 wrote: Well shot those,size lift have you gone for ? May aswell fit caster correction bushes can get them from bits4vits for about 80 quid delivered.ive got a set to go in
Hi I'm fitting 2.5 kit should have said I've got front arms to fit with castor correction bushes these are the rear arms,sorry for any confusion
Cheers Vinnie
07 Sep 2014 12:19 #123530 by kirkynut
Replied by kirkynut on topic Arm bushes
Crickey that's well gone - I'm surprised you hadn't felt it in the car with it steering from the rear etc.
I got bored of the rubber type and went to Super Pro poly bushes. Easier to fit and make the car feel better poised on road - and they do not reduce flex off-road, despite the myth.
  • Vinnie
07 Sep 2014 12:44 #123532 by Vinnie
kirkynut wrote: Crickey that's well gone - I'm surprised you hadn't felt it in the car with it steering from the rear etc.
I haven't had it long picked it up knowing some stuff needed doing and it is standard at moment apart from lift in now doing and some wheels and tyres both from members on site.it isn't to bad on road a little wobble which kinda halved when I fit a new wheel bearing , are the poly ones in two halfs ?
Cheers Vinnie
07 Sep 2014 14:31 #123538 by Johnniehec
Replied by Johnniehec on topic Arm bushes
Good to know Kirkynut, mine are like Vinnie's after about 300 miles (and three trials and two punch hunts). Was thinking of going poly bush last time, will now.
Time to create page: 0.114 seconds
