dohc seal
- mickt
12 years 2 months ago #123478
by mickt
dohc seal was created by mickt
My cam cover appears to have very slight leaks at the front and rear left corner. It is not a running leak but overtime there is a build up of oil especially at the rear down onto the side of engine and gearbox. It is more unsightly than a problem It is MOT time and they do not like to see any of the cars bodily fluids escaping. Is it possible to buy a new gasket by it self or is it a matter of resealing?
12 years 2 months ago #123484
by kirkynut
I doubt it will be an MOT failure as it's not running out but yes you'd need a new gasket.
My advice would be to get one from Suzuki. Yes it will cost more and may even seem expensive - however, my experience has been that cheaper aftermarket cam cover gaskets do not seal for long, drive you round the bend and cost you as much as that more expensive one from Suzuki that works first time.
You will need to fit it dry except where there are half moons for the cams and then use RTF sparingly.
Bolt the cover down slowly working from the inside out in a spiral pattern like you are doing a head gasket and don't do the bolts up too tight to crush the gasket. Use a torque wrench.
- irishguy123
12 years 2 months ago #123485
by irishguy123
Replied by irishguy123 on topic dohc seal
Is one of these the gasket you're looking for?
Official suzuki ebay shop
12 years 2 months ago #123511
by kirkynut
It will be one of those and at great prices too. Well done for sharing that mate I'll save them on My eBay when I get on the computer next!
12 years 2 months ago #123527
by facade
Whilst the cam cover is off, you might as well make a day of it and check the valve clearances.
12 years 2 months ago #123528
by kirkynut
I think it needs shims for the valve clearances, which whilst not an excuse to not replace them if they are slack, it is a royal pain in the bottom compared with the old screw type with locknuts!
Mines got slightly noisier over the years but not to the point I am going to play with them. My cam cover gasket isn't leaking though.
Time to create page: 0.101 seconds
