please help im a jimny virgin
  • jayman4870
02 Sep 2014 15:49 #123227 by jayman4870
please help im a jimny virgin was created by jayman4870
hi hope someone can help with these probs..iv just bought a 1999 jimny with a 2inch lift and 285/75/15 tyres looks cool.BUT now i know why she was cheap.....firstly i noticed that the passenger wheel kicks in a touch at the top(not good),jacked her up and have no play whatsoever so am now stumped nothing is visibley bent,was advised it could be the kingpins,but shouldnt i have play?would they bend?omg help needed....on further inspection found that the drivers side spring looks bent.,,,,ermmmmm ok rephrase... chassis where spring sits dont line up with axle so makes the spring look bent..and driving is scary at 50.oversteer is a understatement,move the wheel a inch and your off the road. would caster corrections cure this? is my axle bent? im lost plz help....so in a word iv got a passenger wheel that toes in at top and a spring on drivers side dont sit stright and cant drive hahahhaha is it a dog yup i fink so.. :( :( :(
  • Basketcase
02 Sep 2014 17:09 #123228 by Basketcase
Replied by Basketcase on topic please help im a jimny virgin
Sounds like mine to me! Haha...no the springs on mine are slightly curved we'll call it the seats don't line up but as for the wheel is there any kingpin bearing grease on the swivel hub?
  • Basketcase
02 Sep 2014 17:11 #123229 by Basketcase
Also I think 285 on a 2" lift is bloody massive! I've got some 235 75 that's big enough and rub a tiny little bit
  • Butta
02 Sep 2014 17:14 #123230 by Butta
Replied by Butta on topic please help im a jimny virgin
The springs always look a little odd on lifted trucks jimnys in particular but post a pic of springs and we can give opinions if the wheel is cambered so it points in at the top I would say most likely king pin because if the axle was bent it would even itself out between the 2 wheels so they would both be the same (being a solid axle) to be honest (in my opinion) it probably needs kingpins, castor correction bushes and a steering damper before it will drive properly
  • jayman4870
02 Sep 2014 19:13 - 02 Sep 2014 19:16 #123241 by jayman4870
Replied by jayman4870 on topic please help im a jimny virgin
sorry the tyres are 235/75/15..when u say kinkpins!!!! now...do u mean the bearings? or the actual kingpin at the top of the hub where four nuts are? im looking now and the spring isnt a problem (i hope) as when i fit the correction bushes think the axle will twist round and the spring i hope will then sit streight...dont think a steering damper would stop the mass oversteer would it? its so light on the steering its scary hahahha with those big tyres aswell omg ...also is it normal for the rear to sit little lower than the front?hmmm
Last edit: 02 Sep 2014 19:16 by jayman4870.
  • Butta
02 Sep 2014 19:51 #123245 by Butta
Usually just kingpin bearings yes but if they are bad enough the kingpin can wear although its unusual, steering damper damps the steering making it less hyperactive my jimny is stock ride height with good kingpin bearings and mud tyres and its a handful especially in the wet
Time to create page: 0.091 seconds
