CV leaking
  • Leathery1
12 years 2 months ago #122849 by Leathery1
CV leaking was created by Leathery1
Hi All.
Got a sudden bad leak of what looks like fairly thin oil from NS CV joint.
I have had a clicking noise for a few weeks but put this down to the newly fitted lockrite.
Whats best, replace king pin bearing and all the seals or just replace whole CV joint? I will do both cos the other one is bound to go soon as well.
Thanks
12 years 2 months ago #122858 by kirkynut
Replied by kirkynut on topic CV leaking
Do you have the clicking in 2wd with the hubs unlocked? If so it's nothing to do with the cv's as they are not turning.
The axle oil seal is leaking diff oil. The cv's are just greased. The cause is probably worn king pin bearings but could be a wheel bearing.
Grease the cv's well when changing the king pin bearings anyway but I doubt you'll have a problem with your cv's themselves.
The following user(s) said Thank You: Leathery1
  • Leathery1
12 years 2 months ago #122911 by Leathery1
Replied by Leathery1 on topic CV leaking
Thanks Kirkynut.
Clicking is in 2wd and I still have original vacuum hubs, so unlocked when in 2WD.
I think I will just change all the seals and the king pin bearings both sides.
Poor old girl has had a bit of a culture shock in the last 18 months, only road use for 13 years, then some mods and plenty of laning plus a couple of P&P outings since, so things are starting to show up.
The lockrite has to go though, we hate it!
  • hunter1084
12 years 2 months ago #122912 by hunter1084
Replied by hunter1084 on topic CV leaking
Leathery1 wrote: The lockrite has to go though, we hate it!
Definitely! For 4wds that are used on road you're better off saving up for an air operated diff lock. More expensive but worth it to keep your road handling
  • Leathery1
12 years 2 months ago #122914 by Leathery1
Wish someone had told me that before I fitted it hunter!
Heavy steering, massive under steer power on, scary tail twitch if you back off mid corner, squeals the tyres every T junction unless you set off like you are 90 years old, vague steering at neutral throttle and I reckon it will be lethal if snows!
And no noticable difference off road as I am not a hard core "if you dont break something you arent trying hard enough" off roader
Time to create page: 0.081 seconds
