Immobiliser
  • bikerjohn57
12 years 2 months ago #122837 by bikerjohn57
Immobiliser was created by bikerjohn57
Help Please, My 2004 RHD Rag top Jimny has decided to let me down again and on the day that the MOT was booked.
She wont start and the immobiliser lock light/icon on the dash is lit.
Had the same problem about 6 months ago, then I disconnected all the sockets under the steering column reconnected them and that cured the problem.
Tried the same thing this time but no luck, maybe it was just fluke the last time.
Saw a company on the web called autotronics who recon they can reprogram the immobiliser, and supply a replacement transponder, but I thought the immobiliser was built into / part of the ECU. Anyone used them ?
Any suggestion's gratefully received.
12 years 2 months ago - 12 years 2 months ago #122939 by Rhinoman
Replied by Rhinoman on topic Immobiliser
The immobiliser is a separate unit, technically its not actually an immobiliser but a transponder interface, it gets the key codes and communicates with the ECU, if the keycodes don't match what is in the immo and the immo codes don't match what is in the ECU then the ECU won't let the car run.
Typically its the immo codes that get corrupted, usually by a badly executed jump start. A repair requires the ECU and immo to be rematched and then the keys to be rematched to the immo. Generally that requires chips removing from the ECU and immo to be recoded/replaced. I think the 2004 has the box piggybacked to the ignition lock, those are a little trickier because there are a couple of capacitors that will crack when the PCB is removed/replaced so they also need to be replaced with a newer/upgraded type.
I can quote you for the work if you PM me.
Last edit: 12 years 2 months ago by Rhinoman.
Time to create page: 0.070 seconds
