Hi, i have a 51reg jimny 1328cc
  • tony-a1
29 Oct 2010 14:23 #5497 by tony-a1
Hi, i have a 51reg jimny 1328cc was created by tony-a1
Hi i have a 51reg 1328cc jimny,whenever i fill the petrol tank over half way it smells of petrol and if parked on an incline it leaks.Can i fit a tank from an 04reg jimny as a straight replacement,or will it req modifiying?
29 Oct 2010 15:55 #5501 by kirkynut
I don;t know if anyone on here has messed about with fuel tanks to now the answer to this, but I know that Darren at KAP will tell you the answer or Rhinoray.
Have you tried some of that stuff you put in your tank that seals it? I quite often see it advertised in magazines.
The following user(s) said Thank You: tony-a1
29 Oct 2010 17:26 #5512 by facade
I bet your tank is leaking from the same place that mine was: the filler hose spigot on the tank.
Due to the usual clever design mud lies on top of the filler pipe, creeps between the rubber pipe and the spigot, and rusts through it.
I fixed mine with that liquid metal stuff that isopon do for mending leaking fuel tanks.
Took ages though, the rubber filler pipe has to come off, and the only way to do that is to cut through the screw in the wire clip that secures the pipe.
I didn't fancy changing the tank, the fuel pump has to come out of the top, and you need some sort of special tool to disconnect the fuel hoses, disturbing them will no doubt set them off leaking..........
  • Garry
30 Oct 2010 16:28 - 30 Oct 2010 16:30 #5562 by Garry
Replied by Garry on topic Re: Hi, i have a 51reg jimny 1328cc
I had my fuel tank of the other week, came off easy, but i can access everthing from the top, as i dont have a rear end on my jimny,
you have to unbolt and remove the rear propshaft to drop the tank out,
there bolts either side of the tank (14mm) that hold the tank onto the chassi,
the fuel pipes are just clipped on to the top of the pump, there is a little bit you have to push in on either side of the clip to release it, this was even a hassle when i was doing it, with easy access!
Last edit: 30 Oct 2010 16:30 by Garry.
  • tony-a1
31 Oct 2010 14:07 #5590 by tony-a1
Replied by tony-a1 on topic Re: Hi, i have a 51reg jimny 1328cc
HI,THANKS FOR ALL THE INFORMATION ITS MUCH APPRECIATED,TONY
Time to create page: 0.168 seconds
