Cambelt Question
- Blitz
24 Aug 2014 22:16 #122682
by Blitz
Replied by Blitz on topic Cambelt Question
Iv just got a 02 soft top on an 04 plate and it's got the old timing belt engine. Thanks to this forum I know otherwise I'd have assumed it's chain drive as every other site will tell you :huh:
- Venter
29 Aug 2014 10:40 #122934
by Venter
Replied by Venter on topic Cambelt Question
So if it's a chain I've got, when should I replace that?
29 Aug 2014 11:26 #122935
by facade
You don't
( unless you are rebuilding the whole engine- this would be so expensive that I doubt if anyone has ever done it, a second hand guaranteed engine would be cheaper)
If it starts to rattle, because of chain wear then it will have been caused by lubrication failure and most likely a cam will have seized before this happens.
Just change the oil & filter regularly and it will last a couple of hundred thousand miles.
Replied by facade on topic Cambelt Question
Venter wrote: So if it's a chain I've got, when should I replace that?
You don't
- GuardianAngel
29 Aug 2014 13:12 #122942
by GuardianAngel
In Australia Jimny's can go for 3, 4 or even 500k km's. Mechanically they are sound it's just in this country rust kills them first.
Replied by GuardianAngel on topic Cambelt Question
You don't( unless you are rebuilding the whole engine- this would be so expensive that I doubt if anyone has ever done it, a second hand guaranteed engine would be cheaper)
- Venter
29 Aug 2014 21:58 #122969
by Venter
Thanks folks
Time to create page: 0.089 seconds
