Rear shock bush help please
- rayz_x
23 Aug 2014 17:04 #122601
by rayz_x
Rear shock bush help please was created by rayz_x
I have a new set of rear shock bushes from Martin - who was very helpful indeed. I managed to get the old bolts off today but now I have compared old and new parts I want to check everything is OK. I will attach a pic of the old and new parts.
The new sleeve and bush are longer than the old ones and a different shape - the bush will stick out either side of the ring. Is this all OK or am I missing something please?
Incidentally - I managed to get a socket and T-bar on the top shock bolts by grinding the pip off the end of the T-bar so it will slide into the socket holder part further (hope that makes sense). The old bolt in pic was the difficult one - drivers side - and just came off before it was too rounded off!
Thanks for any help,
Ray
Ray
- Flameboi201
23 Aug 2014 17:43 #122604
by Flameboi201
Replied by Flameboi201 on topic Rear shock bush help please
Yes thats normal mate . You will have to grind the new poly bush down abit . Because it wont fit in the mount otherwise . Just do it abit at a time and keep trying it . It wants to be a nice snug fit . Hope that helps
- rayz_x
23 Aug 2014 20:00 - 23 Aug 2014 20:03 #122611
by rayz_x
Replied by rayz_x on topic Rear shock bush help please
OK, thank you. This is the length of the bush and metal sleeve I need to take down? Should the mount just pinch the inner metal sleeve when the bolt is tightened? I guess I can just take length off the inner sleeve then cut the poly bush to fit that length?
Ray
Ray
Last edit: 23 Aug 2014 20:03 by rayz_x. Reason: Read the reply properly second time!
23 Aug 2014 20:04 #122614
Replied by mlines on topic Re:Rear shock bush help please
It's the length. The ring on the bottom of different shocks are different sizes so you need to trim the length to fit
Sent from my Nexus 5 using Tapatalk
The following user(s) said Thank You: rayz_x
- Basketcase
23 Aug 2014 20:04 #122615
by Basketcase
Replied by Basketcase on topic Rear shock bush help please
You need to cut/grind the bush so when it's in the shock it sticks out a little bit I think the length of the cylinder should be around 37mm but check first with an old one!
- rayz_x
24 Aug 2014 20:38 #122671
by rayz_x
Thanks everyone, I got them finished today. Getting the old bolts out is the most difficult part, followed by removing the old bushes.
Ray
Ray
Time to create page: 0.104 seconds
