2 questions ?
  • rs200boy
12 years 3 months ago #122397 by rs200boy
2 questions ? was created by rs200boy
ive got 2'' lift kit springs shocks and extended brake lines first question is it wise at this height to change to castor correction bushes in the front arms (also should the rear be done ?)
second question can i fit/ is it wise to fit a body lift kit or would i be needing to change alot more ie different gears pipes etc etc and would it affect the drive badly as i use it for 5 mile commute everyday :silly:
  • GuardianAngel
12 years 3 months ago #122406 by GuardianAngel
Replied by GuardianAngel on topic 2 questions ?
rs200boy wrote: ive got 2'' lift kit springs shocks and extended brake lines first question is it wise at this height to change to castor correction bushes in the front arms (also should the rear be done ?)
I have a 2" lift and my axles are noticably rotated, and the steering wheel kind of returns on its own so I might get corrected bushes when the time comes to replace them.
It could be said the rotation puts a little load on the UJ's but with a 2" lift its probably minimal so maybe not worth worrying about.
  • Back in Black
12 years 2 months ago #122431 by Back in Black
Replied by Back in Black on topic 2 questions ?
Body lift made no noticeable difference to ride quality/stability on mine. I use Jimny for a 20 mile daily commute and haven't had any issues.
You will need to fiddle with the four wheel drive selector so you can get the lever back all the way to low range (once raised the lever will not engage properly), there is a connector for the break lines in the engine bay that will need modding and maybe extend the steering a bit (I just undid the join and raised and re-tightened, there was enough spare length already there - I have a 2000 model, not sure if this varies to other years)
Time to create page: 0.086 seconds
