clicking noise
- suzuki jimny fella
19 Aug 2014 19:01 #122386
by suzuki jimny fella
clicking noise was created by suzuki jimny fella
hi all i fitted new rear bushes today as the old ones failed and i still got the click click as i pull away
it will only do it when i pull away forward for the first time and will not do it in till i reverse then pull away again
IE pull away forward click click stop reverse click click
pull away forward click click stop pull away forward No click click will only click once in one direction hope this all makes sense guys
took rear prop off pull away with fwd no clicking my diff seems to be ok and my lobster box and my prop looks fine
hope you no what i mean it is really bugging me
- rs200boy
19 Aug 2014 21:48 #122401
by rs200boy
Replied by rs200boy on topic clicking noise
possible pad rattle ?have you had your brake pads out lately ??
sounds like the pads are loose in the caliper when you move off the forward motion is moving the pads then the opposite when you reverse
quick check would be remove wheels and see if pads move forwards and back
hope this helps
hope this helps
20 Aug 2014 19:44 #122440
Replied by suzuki jimny fella on topic clicking noise
its from there rear not the front fella
and when rear prop is removed there is no noise
21 Aug 2014 17:15 #122484
by kirkynut
Replied by kirkynut on topic clicking noise
Do the radius arm bush bolts up tighter - a lot tighter!
22 Aug 2014 18:33 #122552
any tighter they will snap lmao it doing my nut in
22 Aug 2014 18:35 #122553
theres no tell tall makes of movement and the holes are in good condition prop looks good diff sounds good could strip it out to look in side
Time to create page: 0.119 seconds
