lock right and freewheeling hubs
  • oxford_bloke
15 Aug 2014 21:55 #122154 by oxford_bloke
lock right and freewheeling hubs was created by oxford_bloke
Just a quick question, i know people have problems when driving bends with a front lockright surely this problem shouldnt occur with free wheeling hubs, or does the same problem occur if there is a lock right in the rear.
in theory,
with two lock rights fitted driving in 2wd and front hubs disengaged all the wheels should spin independently?
am i correct in saying this?
15 Aug 2014 22:32 #122161 by Busta
Lockright's aren't available to fit the front of the Jimny. If they were available then, as you say, with the front hubs unlocked they would have no effect.
The problems people experience with them in the rear are normally due to them not un-locking when turning. Cornering with either diff locked will cause understeer/oversteer/ tyre scuffing.
  • panosd
16 Aug 2014 12:27 #122182 by panosd
Replied by panosd on topic lock right and freewheeling hubs
Yes you can fit a lockright locker at front.
You are going to need the 2 rear side gears from the rear diff.
If you have the lockright at front and the hubs disengaged it will be like a normal jimny.
No effect in driving.
With the front hubs engaged you need to learn it and pre deside your root when on and off road
because the lockright wont let you turn when you want to.
Time to create page: 0.086 seconds
