Kingpin bearings.
- Davey65
12 years 3 months ago #122042
by Davey65
Kingpin bearings. was created by Davey65
If the grease is leaking out near to the wheel is this a MOT fail ?
Thanks.
Thanks.
12 years 3 months ago - 12 years 3 months ago #122088
by facade
Replied by facade on topic Kingpin bearings.
Not if you wipe it off so it isn't running over the tyre
Seriously, the grease will indicate something is wrong, however any competent tester will find that the kingpin bearings have gone, which is an MOT fail.
He jacks the front axle up to get the wheels off the floor, then uses a BIG lever to try and lift the wheel up, whilst looking for movement of the swivel housing.
A drip of grease won't hurt, the Jimny doesn't have sealed swivels full of oil like a Landrover, and some grease comes out naturally.
Last edit: 12 years 3 months ago by facade.
The following user(s) said Thank You: Davey65
- rs200boy
12 years 2 months ago #122402
by rs200boy
Replied by rs200boy on topic Kingpin bearings.
as above i failed a jimny today passenger side little bit of grease over as expected PASS
drivers side alot of brown grease around ball and had been dripping onto tyre and also top to bottom play revealed kingpin bearings shot FAIL tomorrows work for me
Time to create page: 0.073 seconds
