Transmission noise
- Butta
- minibbb
- Butta
does sound like diff but it is confusing me that it doesn't do it in first even if you go faster in first and slower in secondminibbb wrote: Does it come from the back of the car?? My 111k 2005 has done it since I bought it at 109k. Assuming its diff noise. Changed the diff oil and hasn't changed it- doesn't bother me as the car functions perfectly and I can't be doing with swapping out diffs unless I have to!
- macguyverjimny
Strap a gopro next to the diff to see if it records huge amount of noise in the video?
I also had gearbox problems, but mine was only in gears 2,3 and 4,
So it could be determined to be premature bearing failure.
Hope this helps.
- Butta
same in 5th gear and different gearbox to vvt model but could be gearbox I suppose but how much noise is normal for a twin cam jimny?macguyverjimny wrote: Check if the noise dissapear at 5th gear!?
Hope this helps.
- Basketcase
