Jimny problems, question about parts quality.
- macguyverjimny
12 Aug 2014 06:29 #121810
by macguyverjimny
Jimny problems, question about parts quality. was created by macguyverjimny
Hi guys,
Havent been posting on here for a while,
Have had some major costs on my jimny, a while back i posted about a whining noise in my jimny.
Turned out they replaced all the bearings in the VVT gearbox,
Also replaced a clutch recently,
Replaced Broken clucth cable,
General mantainance like belts, filters, ect.
Now there is a new oil leak after the repairs to the gearbox.
It feels like the jimny just keeps on giving costs.
Cant believe it, i havent been offroading with it for a while....
What are your guys thoughts on this, ?
It is almost at 80 000 kilometers on the clock.
Is there some advice from the older lads,?
At the moment the car doesnt get repaired by me , but by a reputable garage.
Here is a pic of the car going to repairs due to the new oil leak.
Thank you guys.
Thank you guys.
- Xtreme
12 Aug 2014 06:58 #121811
by Xtreme
Replied by Xtreme on topic Jimny problems, question about parts quality.
Try to do servicing yourself - in terms of general service, oil change, filters etc, diff oil and all that. They are very easy to work on and why pay labour for something you can do in about 40mins? You also know the right oil and filters are being used. If people not mechanically minded can do it easily by following a service manual, and you also get to know and become familiar with your car.
For major mechanical issues for most of us it has to go to a qualified mechanic. You need to be satisfied with their work or get them to fix it until you are.
Having said that, once the works have been carried out you then can be confident that it should last you a long time before requiring work again. Sometimes it seems that cars cost too much, but even new ones can cost alot of money the moment they go out of warranty, its luck of the draw really.
I just bought a car for the wife, went $2000 over budget because I thought it was in far better condition then the others I had seen, the week after it cost me a further $1800 getting the whole front end suspension set up replaced because it had terrible wheel wobble at highway speeds. It is now not worth what I have paid for it, but I am happy because I know the money has been spent to ensure safe handling and stopping which is important in the family car. I did all the other servicing myself.
So you get to the stage with every car that they cost you more then you can make back, but if the work is done right then you will have a well serviced, well maintained car that will not continue to cost again on the parts that have been fixed.
- macguyverjimny
12 Aug 2014 07:25 #121813
by macguyverjimny
Replied by macguyverjimny on topic Jimny problems, question about parts quality.
Thanx for the reply xtreme,
Does the breaks an repairs look resonable for the amount of milage!?
Thank you for the help, i really had my confidence back in my car but then the last oil leak got me thinking again.
Luckily the company who did the repairs on the gearbox, have to fix it becasuse of a 1 year warranty they gave.
And the car didnt leak oil one bit before the repairs to the vvt gearbox was done.
- Xtreme
12 Aug 2014 11:11 #121832
by Xtreme
No such thing as reasonable for the amount of mileage it all comes down to how its used and how its maintained.. At the end of the day they are mechanical and things can and do go wrong. If you had problems with motors blowing up and had put in 3 motors and all did the same thing, then you would lose that brand of car. If you get rid of the Jimny and get another one or even a different car there is no way of being sure that one wont cost money either. You are better off sticking with it and working out the problems then you ARE assured of having a mechanically sound car. The Jimny is a great car I reckon, if you want to wheel them hard you might upgrade a few parts but they are fairly capable.
Keep on top of them so its fixed right then get out and have fun:)
By the way I have owned too many beetles for oil leaks to worry me ever!
12 Aug 2014 16:03 #121845
by Busta
Replied by Busta on topic Jimny problems, question about parts quality.
It all depends what you expect from a car. Replacing all the bearings in a gearbox is a bigger job than replacing the whole unit, so if you'd kept using it 'till it broke the bought a replacement you'd be better off in the long run. Gearboxes can whine for thousands of miles before failing! Aside from the gearbox, nothing on your list is particularly surprising. If you want any car to be perfect all the time it is expensive.
I just put up with the whining noises and oil leaks, don't fix things that aren't broken and do all the work myself. That's all the major costs taken care of!
- GuardianAngel
12 Aug 2014 17:06 #121856
by GuardianAngel
Replied by GuardianAngel on topic Jimny problems, question about parts quality.
Learning to do most things myself has saved a LOT of cash and given me the satisfaction of learning new things.
Time to create page: 0.116 seconds
