gear ratio help
- Brave
12 years 3 months ago - 12 years 3 months ago #121686
by Brave
gear ratio help was created by Brave
Hey all after some help with gearing options, I'm sure this has been asked a thousand times but this is different..... Honest.
Ok so i have a 2014 Jimny jlx non-vvt
The brochure stated that the gearing was the same as the VVT model but after doing some rpm to speed calculations and using the global suzuki site for possible options i have found out this is incorrect.
5MT VVT Gear raito
4.425 4.425 1st
2.304 2.304 2nd
1.674 1.674 3rd
1.190 1.190 4th
1.000 1.000 5th
5.151 5.151 Reverse
3.416 4.300 Final gear ratio ( Diff?)
1.320 1.000 Transfer High
2.643 2.002 Low
(sorry this is a mess it works on the post/edit page. basicly first set of numbers my car 2nd vvt))
As you can see my transfer box already has a 32% reduction over the VVT. but i have no idea what chain is being used. I am guessing that it would be the same spec as the VVT M/T, also i have seen specs of new Japanese models that will be using thew same non-vvt gearing but with a vvt engine.
I have contacted both a reduction gearing supplier and protrack who have been very helpful and have given me the following options. But were thrown by the non-vvt spec.
Supplier 35%
Protrack -17 high -87 low.
Unfortunately both would be no good as these were offered for the "VVT"model
Does anyone have any ideas? would I be able to fir the VVT diffs to give me a 25% reduction, or would i be able to fit the Supplier 65% reduction gearing (from stock VVT, I've yet to work out what that would be in mine).
though the vvt has 83.8 bhp and non has 80.4
Again thanks
5MT VVT Gear raito
4.425 4.425 1st
2.304 2.304 2nd
1.674 1.674 3rd
1.190 1.190 4th
1.000 1.000 5th
5.151 5.151 Reverse
2.643 2.002 Low
Supplier 35%
Again thanks
Last edit: 12 years 3 months ago by Brave.
Time to create page: 0.064 seconds
