ORA transfer guard
- irishguy123
12 years 3 months ago #121516
by irishguy123
ORA transfer guard was created by irishguy123
I spent today wrestling with my ORA guard and i've finally got if fitted. However on the longer side where you bolt it to the existing transfer mounts, it just about fitted on.
There was just about enough through protruding from the bottom of the mounts to get the nut on fully. Is this normal or will I have to look at it again?
Cheers
Cheers
- Spendersjim
12 years 3 months ago #121533
by Spendersjim
Replied by Spendersjim on topic ORA transfer guard
Sounds about right.
Those bolts are part of the mount so are a standard length.
I found the other side more hassle and ended up using longer bolts and fixing them in the holes before fixing the plate to them.
- irishguy123
12 years 3 months ago #121563
by irishguy123
Replied by irishguy123 on topic ORA transfer guard
Yea the other side was a fiddle as well, I managed to sort it with some deep offset spanners. It would have been a good place for those bolts on a stick i've seen that some kits come with!
- Spendersjim
12 years 3 months ago #121601
by Spendersjim
Yeah I've seen them too, was going to make some up but in the end just bit the bullet and went for it.
How did you get on with the fuel tank guard?
I've been thinking about one of those myself.
- irishguy123
12 years 3 months ago #121658
by irishguy123
The fuel tank guard is actually fine to fit, but its removing the old one that is the problem as mine was rusted up quite badly. If you have a decent 6 sided socket set and a long extension bar then getting the old bolts out with out them rounding off or snapping should be possible.
- Spendersjim
12 years 3 months ago #121678
by Spendersjim
Ideal, thanks for the info.
I may see if I can splash a bit of WD40 up around them to ease extraction.
I've got some nice impact sockets that are 6 wall drive so will use them.
Cheers
Cheers
Time to create page: 0.086 seconds
