4wd light flashing
  • Atkinson
12 years 3 months ago #121513 by Atkinson
4wd light flashing was created by Atkinson
Hi all.
I have a 2006 jimny 2wd 4wd and 4L selectable on the dash,
I selected 4wd this morning I heard it engage but didn't notice the green
4wd light flashing.
After I had finished with the 4wd I then noticed the green light
Flashing, I then tried to select 2wd and there was nothing, not a
Sound of it trying at all, so now I'm in 4wd all the time.
Can anybody help out please and will it do it any damage
If I carry on driving it.
Cheers mick
12 years 3 months ago #121517 by Halford
Replied by Halford on topic 4wd light flashing
the green light goes solid when in 4wd ..... not flashing,
but if you're defo in 4wd ............ don't drive it at all or you'll destroy it
someone here will tell you how to get back into 2wd and let you drive it,
but I can't remember the procedure and am off to bed (up at 04.00)
The following user(s) said Thank You: Atkinson
  • Atkinson
12 years 3 months ago #121518 by Atkinson
Replied by Atkinson on topic 4wd light flashing
Thanks for the advice, yea it's in 4wd
If you do remember it would be much appreciated.
Thanks again
12 years 3 months ago #121558 by Rhinoman
Replied by Rhinoman on topic 4wd light flashing
You can remove the positive lead from the battery and wait a few minutes, that will mess up your radio codes if you have a coded radio or you can use a Suzuki scan tool to reset the ECU. I had this problem once and the tcase was clearly stuck in 4wd although the hubs were not engaged. I was doing about 60mph and I held the steering wheel straight, hit 4wd and it engaged and then I quickly switched back to 2wd.
12 years 3 months ago - 12 years 3 months ago #121623 by Halford
Rhinoman wrote: You can remove the positive lead from the battery and wait a few minutes
good to know thanks .... going to try that out ;)
Last edit: 12 years 3 months ago by Halford.
12 years 3 months ago #121650 by Rhinoman
It seems to be caused by sticky solenoids or maybe bad connections to the solenoids. Mine started flashing again yesterday when I tried to use 4wd, today it suddenly came on solid while driving down the road, I hit 2wd and it went off again - maybe its time to change the tcase oil. I didn't get round to plugging in the scan tool to see what the fault was.
Time to create page: 0.090 seconds
