crankshaft pullye
  • MG1
12 years 3 months ago #121418 by MG1
crankshaft pullye was created by MG1
Hi All,
Reading around I've come across the crankshaft pulley issue on the 16v engine, such as the thread below but did not want to hijack it. But do people know is it problem across the M13A engine range for all years, or just a bad batch. I have an 03 16v and figure if it is the rubber that breaks down then I'm probably on borrowed time. I normally carry spares of common problems but this is quite a pricey on to have sat is a box but if it is only a matter of time I would rather have one to hand.
Thanks
  • VicInnewquay
12 years 3 months ago #122321 by VicInnewquay
Replied by VicInnewquay on topic crankshaft pullye
Mine went a couple of weeks ago. its a 2005 auto with 54k miles on it.
I needed the car quickly and I'm glad I did the job myself as I reckon the labour charge would have been hefty.
Parts alone were £240, that included both belts. I thought if I am dismantling my way in, I may as well change them while I had the room.
The radiator needed to be loosened at the top so you could get a bit more room to remove the fan off the water pump pulley. To make it easier to refit, I cut the fan housing at the bottom so I could fit the fan without the housing and then 'feed' the housing into position. I then siliconed the cut together after it was in position. I should have fitted a small clamp and a couple of bolts to hold it together, which would have been better, but after 5 hrs I was losing the will to live, along with a lot of skin off my knuckles. Been ok since.
Vic
Time to create page: 0.099 seconds
