oil coming from between engine and gearbox .?
- Flameboi201
04 Aug 2014 18:43 #121351
by Flameboi201
oil coming from between engine and gearbox .? was created by Flameboi201
Hi guys . Noticed abit of oil coming from between back of the engine and dripping out the front of the gearbox . Onley abit but it drops on the exhaust and stinks . Any ideas ?clutch is nearly done anyway and prob contaminated which would make sence as i get abit of a judder when setting of sometimes . Thanks in advance
its a 1.6 16v grand vitara engine .
- gaz3359
04 Aug 2014 19:46 #121362
by gaz3359
Replied by gaz3359 on topic oil coming from between engine and gearbox .?
More than likely the rear main oil seal behind the flywheel ? If your on putting a clutch in its only an extra few minutes to change and a few quid for the seal.
- Flameboi201
04 Aug 2014 20:27 #121364
by Flameboi201
Replied by Flameboi201 on topic oil coming from between engine and gearbox .?
Tidy . Ill order one with the clutch kit . Thanks allot
- Butta
05 Aug 2014 08:22 #121379
by Butta
Replied by Butta on topic oil coming from between engine and gearbox .?
Very common for crank seal to fail on grand vit hardest part of job is undoing flywheel bolts air tools are best otherwise you may struggle
