Problem with my jim after drowning it.
- Docmartin4x4
03 Aug 2014 16:54 #121300
by Docmartin4x4
Problem with my jim after drowning it. was created by Docmartin4x4
Last week went to Frickley and showed my fellow mudpluggers just how good Jim was...... until I got into a bit of bother in 3 1/2 foot of thick muddy water! I just about got out but had a rag wrapped around my crankshank pulley which tore the crank seal......lots of oil everywhere! Anyway got back home changed the crank shaft seal and pulley as it was cracked, started Jim up and oh dear.....ticked over at 2200rpm and would not want to rev up at all. I have checked every connection, pulled it apart and WD40'd everywhere, she did drag some muddy water through the air filter (plug came out of bottom of air filter box) I have removed and cleaned the MAF sensor and now it ticks over fine but is struggling to rev, if I rev it slowly and hold the revs it is fine at any level it is ok but will not rev freely. Give me some idea's please guys!
Mart
Mart
- Butta
03 Aug 2014 17:04 #121301
by Butta
Replied by Butta on topic Problem with my jim after drowning it.
If you have checkd all electric conectors how about check inlet manifold for vacuum leaks although unrelated can give same symptoms
03 Aug 2014 17:50 #121303
by facade
Replied by facade on topic Problem with my jim after drowning it.
Is the exhaust full of dried mud?
Did you pull of a wire to the exhaust gas sensors?
- Docmartin4x4
03 Aug 2014 17:53 #121304
by Docmartin4x4
Replied by Docmartin4x4 on topic Problem with my jim after drowning it.
erm! might just check that, although I can engage 4wd!
Mart
Mart
03 Aug 2014 19:07 #121306
by Rhinoman
Replied by Rhinoman on topic Problem with my jim after drowning it.
I would do a compression test to make sure nothing got damaged internally. If that checks out OK then check the fuel filter, you may have water in the fuel tank.
- Docmartin4x4
03 Aug 2014 19:36 #121307
by Docmartin4x4
Hey Rhinoman, where is the plug to check the engine management codes? Is it directly under the steering wheel and which 2 wires do I bridge out to get get the code?
Mart
Mart
Time to create page: 0.101 seconds
