Rear lock right locker
  • Millzy
12 years 3 months ago #120862 by Millzy
Rear lock right locker was created by Millzy
Hi there every body I'm having problem with my new locker I brought from jimny bitz it's only been in about week and now it seems when I go around corners that it won't unlock like usually would I normal get a click click noise when turning indicating it's unlocking. But now when I take corners it locked And I can hear the tyres sliding on the dry rd
12 years 3 months ago #120863 by funkyjimny
Replied by funkyjimny on topic Rear lock right locker
There is probably plenty of advice on here already, certainly more than a few topics on lockrights so do a search. Rus at Jimnybits is also pretty knowledgable and worth an email.
Gary
  • TomDK
12 years 3 months ago #120865 by TomDK
  • Dave cc
12 years 3 months ago #120866 by Dave cc
Replied by Dave cc on topic Rear lock right locker
Try www.shouldhaveboughtARB.com :laugh: :laugh:
  • supergaz
12 years 3 months ago #120898 by supergaz
Replied by supergaz on topic Rear lock right locker
Did you use your original shim washers or the thicker new ones supplied in the kit? If you used the thicker washers then it wont unlock.
  • TomDK
12 years 3 months ago #120901 by TomDK
Replied by TomDK on topic Rear lock right locker
supergaz wrote: Did you use your original shim washers or the thicker new ones supplied in the kit? If you used the thicker washers then it wont unlock.
Does not make much sense.
In the kit are 2 washers. But they are 4-5mm thick and need to be installed, no matter what. It's the thick shim on each sidegear you may need to remove to get the locker to unlock.
Time to create page: 0.113 seconds
