winch battery
- Jimny_Aus
18 Jul 2014 06:06 #120216
by Jimny_Aus
Replied by Jimny_Aus on topic winch battery
ive got a Jimny bits tray but note sure if ill be using it, plus id rather make my own if that what i need to do to make the battery fit.. theres still a few more option to investigate yet.. thanks though... your system looks great.. are you running a winch aswell ??
i got a 4000lb one rock up this arvo....
- jtayl153
18 Jul 2014 06:47 #120218
by jtayl153
Replied by jtayl153 on topic winch battery
Yeah Im running a WARN VRS 9500lb winch with synthetic rope.
I reckon it could pull me vertically up a tree! Not keen on testing that out though!
Doing my 1.8L conversion next week. With that it might be time for a bigger starting battery
- Big_Sam
18 Jul 2014 15:34 #120240
by Big_Sam
Replied by Big_Sam on topic Re:winch battery
I used to have an Optima Yellow top in the range rover, I was amazed what it could do.
-8°C, frozen fuel lines (lpg converted but had to start on petrol), cranked the starter (in between breaks to let it cool) for over 20mins with no loss of speed or apparent volt drop.
However, when parked up I forgot to disconnect the battery and after a month it was flat, jump starting and driving about was not charging it, and when charged it would not hold the charge, I think fully discharging it killed it.
So great batteries as long as you look after them.
I would get one again, but will probably try an Odyssey pc1500 as like the look of it.
Sent from my GT-I9300 using Tapatalk
- oxford_bloke
19 Jul 2014 16:28 #120292
by oxford_bloke
Replied by oxford_bloke on topic winch battery
Im fitting a pair of numax cvx-1000 to runn two winches and as a starter battery i have manged to shoehorn one into the place of the old one with a bit of tin bashing and bracket trimming
- Bits4Vits
19 Jul 2014 17:57 #120304
by Bits4Vits
Replied by Bits4Vits on topic winch battery
I've got an Odyssey PC1200 from the ORA in an (ABS) JimnyBits battery tray, with a T-Max saplit charge system (also from JimnyBits) to power my front (and rear soon) winch(es)... came highly recommended
- TomDK
19 Jul 2014 18:22 #120309
by TomDK
Why not just use the PC1200 for everything? There's no reason to stick with the old cheap standard battery when you have an excellent quality Odyssey battery installed as well.
Replied by TomDK on topic winch battery
Bits4Vits wrote: I've got an Odyssey PC1200 from the ORA in an (ABS) JimnyBits battery tray, with a T-Max saplit charge system (also from JimnyBits) to power my front (and rear soon) winch(es)... came highly recommended
Time to create page: 0.113 seconds
