Rear Diff Noise
  • MG1
12 years 4 months ago #119942 by MG1
Rear Diff Noise was created by MG1
Hi All,
I have a clonking noise coming from my rear diff area when pulling off in first or reversing from stationary, 2003 non abs model.
Looking on this site I originally went for radius arm bushes, then rear prop shaft UJ all replaced without getting rid of noise. I took it to my local garage today and whilst I was going back and forth from rest over the pit they were sure the noise is coming from the rear diff.
Given that it drives fine I'm not sure it is worth the cost of replacing the whole diff, which was their advice.
Does anyone have experience of a similar problem or have a suggested way forward without just going for a new diff.
Any advice welcome,
Thanks
  • supergaz
12 years 4 months ago #119944 by supergaz
Replied by supergaz on topic Rear Diff Noise
Is the flange nut tight? You will need to remove the prop shaft the check.
  • Flameboi201
12 years 4 months ago #119956 by Flameboi201
Replied by Flameboi201 on topic Rear Diff Noise
Put it in gear and rock it back and forward using the back wheel and look at the rear axle while you do it this should help you find the noise /problem . Mine did the same and it was the radius bushes .i could see the axle rocking back and for . Obviusly youve repleced all 6 of them but should help u pinpoint the problem . Hope this helps . If you think it is the diff put a screwdriver on the diff casing and put your ear to the handle to your ear as someone rocks in forward and back and youll be able to hear the clunk better
  • MG1
12 years 4 months ago #119962 by MG1
Replied by MG1 on topic Rear Diff Noise
Just removed prop shaft, the shaft into the diff has a key way type slot in it. The flange nut has been tapped into the slot to prevent the nut coming loose. So I suspect this means that the flange nut cannot come loose as it cannot move independently of the shaft, unless I'm missing something.
I will try the tricky rocking the wheels with the car in gear tomorrow.
Thanks
  • MG1
12 years 4 months ago #120011 by MG1
Hi,
Just tried rocking car back and forth as suggested. I was convinced that the noise came from the diff housing. However I removed the prop shaft and repeated the process and there was no clunk. Having changed the rear UJ does this suggest that it is the front joint on the prop shaft which I believe cannot be replaced/serviced.
Thanks
Time to create page: 0.117 seconds
