brake warning light stays on
- chalks
14 Jul 2014 16:02 #119941
by chalks
brake warning light stays on was created by chalks
:dry: Hi, Had my Jimny 2months - 2002 model. The brake warning light stays on. I've investigated the handbrake switch - no problem there.. The fluid level is good. I disconnected the lead from the reservoir - light stayed on. It is erratic but is on more than off. Any ideas,advice or help would be most welcome.
14 Jul 2014 17:13 #119946
by j999pre
Grey pick up Jimny
Replied by j999pre on topic brake warning light stays on
Flick the ignition key back a touch after you start it.
Grey pick up Jimny
The following user(s) said Thank You: chalks
- steffan
14 Jul 2014 20:25 #119969
by steffan
Replied by steffan on topic brake warning light stays on
Is the fluid low
14 Jul 2014 22:48 #119986
by Busta
Replied by Busta on topic brake warning light stays on
Common fault with the ignition barrel.
As j999pre says, just turn the key back slightly once it's started and the light goes out. I'm not sure if there is a fix without replacing the whole barrel.
Time to create page: 0.083 seconds
