Soggy brakes even after bleeding
  • GuardianAngel
10 Jul 2014 17:48 #119708 by GuardianAngel
Replied by GuardianAngel on topic Soggy brakes even after bleeding
Or if you don't know what you are doing take it to the garage and pass the liability to them in case something does go wrong.
  • bigoffroader
10 Jul 2014 18:14 #119710 by bigoffroader
Replied by bigoffroader on topic Re:Soggy brakes even after bleeding
GuardianAngel wrote: I put the rear wheels up on ramps then the fronts when bleeding. Air rises so this I figure this helps with helping the air along.
Have you bled in the right order, I.e. starting furthest away from the master cylinder and working your way in?
To save me putting it on ramps I used my drive which is very steep as I thought the same I did the rear the turned the truck round and did the front.
Yes bleeding them in the correct order, as I say I build and fitted the rear disc conversion a couple if years ago and fitted it with no problems
  • bigoffroader
10 Jul 2014 18:17 #119711 by bigoffroader
Replied by bigoffroader on topic Soggy brakes even after bleeding
Busta wrote: Possibly a seized caliper?
No seized calipers as I've had them all off to check and they all work as they should
  • bigoffroader
10 Jul 2014 18:19 #119713 by bigoffroader
markyp2000 wrote: Clamp off all the hoses and remove one clamp at a time when bleading unless thay are braided ones
Unfortunately I have braided hoses all round, otherwise that would have been my next step
I am starting to wander if air has got into the master cylinder, and I need to bleed that?
  • bigoffroader
10 Jul 2014 18:22 #119715 by bigoffroader
GuardianAngel wrote: Or if you don't know what you are doing take it to the garage and pass the liability to them in case something does go wrong.
Not normally the case, it should be a simple case of 10 mins job done,as it has been in the past, just cant see what ive missed,as I say I built the conversion kit and fitted it with no problem.
  • GuardianAngel
10 Jul 2014 21:47 #119727 by GuardianAngel
Sorry did not want to imply you didn't, but we do have posters here who clearly don't know and it's just better to be safe than sorry with brakes.
Time to create page: 0.172 seconds
