Soggy brakes even after bleeding
  • bigoffroader
09 Jul 2014 19:28 #119604 by bigoffroader
Soggy brakes even after bleeding was created by bigoffroader
Hi
Has anyone got any advice on bleeding brakes on a jimny?
I've never had any problems before bleeding brakes on any car i have had, even when I first fitted the rear brake conversion on the jimny. I have just replaced the rear passenger side caliper and now I can't get the brake pedal to harden up.
It feels fine without the engine running, but once the engine is started the pedal drops and its a soft pedal
I have bled the brakes over and over but can't get them any better.
Any advice, before I revert to a drastic last resort and take it to the garage?
09 Jul 2014 19:51 - 09 Jul 2014 19:57 #119610 by dirtydogz
Have you bled the rear brake balance valve first, that has a bleed nipple on it.
2002 JLX Soft Top B)
Jimnybits 2" lift +Pro Comp ES1000 shocks.:) Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
Last edit: 09 Jul 2014 19:57 by dirtydogz.
  • bigoffroader
09 Jul 2014 20:15 #119620 by bigoffroader
Replied by bigoffroader on topic Soggy brakes even after bleeding
Yes bled the balance valve
  • GuardianAngel
09 Jul 2014 21:18 #119628 by GuardianAngel
Replied by GuardianAngel on topic Re:Soggy brakes even after bleeding
I put the rear wheels up on ramps then the fronts when bleeding. Air rises so this I figure this helps with helping the air along.
Have you bled in the right order, I.e. starting furthest away from the master cylinder and working your way in?
10 Jul 2014 11:25 #119669 by Busta
Possibly a seized caliper?
  • markyp2000
10 Jul 2014 17:14 #119701 by markyp2000
Replied by markyp2000 on topic Soggy brakes even after bleeding
Clamp off all the hoses and remove one clamp at a time when bleading unless thay are braided ones
Time to create page: 0.563 seconds
