Sagging Jimny
- Sprocket
12 years 4 months ago #119403
by Sprocket
Sagging Jimny was created by Sprocket
I put a 2 inch lift on my jimny last year and I've noticed this summer that it has started to sag on the offside rear corner. It's about 20 mm lower on that side. Any ideas out there what the cause is. I'm thinking that either the spring on that corner is failing, the spring mounting is failing or all jimny's are like this and I'd never previously noticed.
Next weekend I'm going to take the springs out so that I can check the free length and also have a look at the mounts but any ideas would be appreciated
- Butta
12 years 4 months ago #119404
by Butta
Replied by Butta on topic Sagging Jimny
I would check mounting points and swap springs between o/s and n/s if it still leans the same get a spring trim packer for the o/s to level it up
- Sprocket
12 years 4 months ago #119407
by Sprocket
Replied by Sprocket on topic Sagging Jimny
Cheers, I'll check that and see what I can do.
- Sprocket
12 years 4 months ago #120098
by Sprocket
Replied by Sprocket on topic Sagging Jimnytop or the bottom of the spring
Hi Again
I've got some spring trim packers which I plan to fit at the weekend but looking at them I'm not sure if they fit at the top or the bottom of the spring. My guess is top but if someone can confirm I'd appreciate it.
- supergaz
12 years 4 months ago #120108
by supergaz
Replied by supergaz on topic Sagging Jimnytop or the bottom of the spring
Jimny Lean is common, just google it. Most quality lift kits come with a longer spring for the offside front.
- Sprocket
12 years 3 months ago #120359
by Sprocket
OK thanks for the tip. I just took the front springs out and both are the same length, 380 mm. I've put both back with a 25mm super pro packer on the drivers. Both sides at the front are now 810 mm to the arch. Still got a bit of a lean at the back of the car but I've got 15mm packer to go in there.
Time to create page: 0.083 seconds
