new radiator problem... maybe.
- Danjamin
12 years 4 months ago #119267
by Danjamin
new radiator problem... maybe. was created by Danjamin
In the past year i have had the cam belt, water pump, and head gasket replaced.
Today i put a new radiator and radiator cap in. i filled it up with new coolant and filled the expansion tank let it heat up to running temperature with the heater on full blast, topping up the rad till it wouldn't take any more water.
The problem im having is when i got back from taking it round the block the top hose was hot. the bottom hose was cold and there was no pressure in the pipes and the radiator water level was correct.
the temp gauge hasn't gone above the normal running temp (half gauge)
oh yeah. the top hose has water in it but no pressure.
all was normal till i replaced the dead radiator.
have i mucked up anywhere? or made any schoolboy errors? or do you think i may not have got it hot enough? ( i ran it for about 15-20 mins on the drive way then nipped to get fuel)
Cheers for any help
Ben
Cheers for any help
Ben
- Dave cc
12 years 4 months ago #119275
by Dave cc
Replied by Dave cc on topic new radiator problem... maybe.
Take it for a longer run keep a watchfull eye on the gauge dont soynd like the thermostat has opened yet is the heater coming through warm ?
- Danjamin
12 years 4 months ago #119277
by Danjamin
Replied by Danjamin on topic new radiator problem... maybe.
Yeah. The heaters got warm.
- Dave cc
12 years 4 months ago #119279
by Dave cc
Take it for a longer run keep eye on temp gauge take water with you in case its air locked and needs topping up
- Danjamin
12 years 4 months ago #119281
by Danjamin
Cheers. Il take it for a drive when I get back from work.
- Danjamin
12 years 4 months ago #119310
by Danjamin
Cheers dave. Just got in and tanned it up the bypass. It's running sound now.
Time to create page: 0.092 seconds
