noises from my Jimny
- TomDK
30 Jun 2014 19:25 #119070
by TomDK
noises from my Jimny was created by TomDK
First, For some time the gearbox has made some strange noises. It's only in 3rd and 4th gear, and only when pulling at low rpm. Below 2500 rpm. sounds a bit little a subtle rattle. Anyone else experienced this? What could be the cause of this?
Second, I've recently discovered a whining noise, not sure where it comes from but it only occurs from around 2200 rpm and up. Sounds a bit like a turbo spooling up.. Well not exactly, but can't come up with anything better to compare with
- dumb_dom
19 Jul 2014 17:24 #120298
by dumb_dom
Replied by dumb_dom on topic noises from my Jimny
I've just had the clutch replaced in my jimny and I'm having these problems! I can't find the answer anywere I've been told it's a big possibility it could be the gearbox or low transmission fluid! I hope someone knows the answer! Keep me posted!
- Bits4Vits
19 Jul 2014 17:50 #120303
by Bits4Vits
Replied by Bits4Vits on topic noises from my Jimny
When I was building mine I accidently ran it without the intermediary prop in, and it chucked about half a litre of oil out... I remembered at the end of the build to top the oil back up in the gearbox as it was rattling a little on idle...?
Might help... check the oil level in your gearbox?
- dumb_dom
19 Jul 2014 17:58 #120305
by dumb_dom
Is their an easy way to do this?
- Bits4Vits
19 Jul 2014 18:12 - 19 Jul 2014 18:17 #120308
by Bits4Vits
I just used an oil 'syringe' to suck some out of a bottle then pump it into the oil filler on the (driver's) side of the gearbox until it weeps out, that gives you your level...
You'll need a 3/8" square filler cap tool, and the syringe/pump is essential as there's only a couple of inches between the gearbox and the transmission tunnel...
Last edit: 19 Jul 2014 18:17 by Bits4Vits.
- dumb_dom
19 Jul 2014 19:34 #120318
by dumb_dom
Brilliant I'll buy them bits on Monday while I have a day off work, any oil type/ weight you would recommend?
Time to create page: 0.092 seconds
