Rear prop shaft
- lb2e04x
28 Jun 2014 21:47 #118930
by lb2e04x
Rear prop shaft was created by lb2e04x
Hi all,
well after driving about listening to a chink a chink from what I thought was the exhaust, turns out to be the rear prop shaft.
Got it up on stands and had a look see. The front end of the shaft appears to go into a cup which is the part making the sound.
Is this part mendable or do I need a new shaft?
thanks
Dave
Shaftesbury
Dorset.
thanks
Dave
Shaftesbury
Dorset.
28 Jun 2014 21:52 #118931
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Rear prop shaft
I think it's a replacement shaft you need. Someone may know better on here though.
I have one if your looking
Grey pick up Jimny
The following user(s) said Thank You: lb2e04x
28 Jun 2014 23:21 #118941
by KJS
Replied by KJS on topic Rear prop shaft
Yup new one needed, the front joint is not a serviceable part. I sent mine to Dave Mac propshafts and they made me one with renewable uj's at both ends and grease nipples for the uj's and slide - I did post a pic on here somewhere. It has been running for some time now with no problems at all.
- gus2000
29 Jun 2014 01:38 #118943
by gus2000
Replied by gus2000 on topic Rear prop shaft
Hello, my friend Santiago lubricate the Jimny CV joint
Suzuki do not provides rubber dust cover, a generic one is used
Use only grease for CV joints (Molykote Dow corning BR2 plus, or equivalent)
Many (one in each Groove) Nylon Cable Ties over rubber is essential to avoid the centrifugate rubber dust cover.
In the photo they are insufficient Cable Ties
Cheers
Gustavo
Cheers
Gustavo
- Dave cc
29 Jun 2014 08:26 #118955
by Dave cc
Replied by Dave cc on topic Rear prop shaft
I've got a couple depends where you are tenner if you want to swing by
- lb2e04x
29 Jun 2014 20:06 - 29 Jun 2014 20:10 #119007
by lb2e04x
Replied by lb2e04x on topic Rear prop shaft
Thank you all.
Looks like another one needed.
Yes please to all offers, who is closest to Shaftesbury or Salisbury where I work.
Happy to pay squillions, how much for it and postage?
thanks Gus for the repair breakdown but a replacement looks easier.
Dave
Dave
Last edit: 29 Jun 2014 20:10 by lb2e04x. Reason: add text
Time to create page: 0.120 seconds
