Bushes trashed
  • supergaz
26 Jun 2014 07:04 #118649 by supergaz
Replied by supergaz on topic Bushes trashed
I also use the Superpro poly bushes and believe they flex well, also give good road manners if the jimny has any. Mine have been on for about 4 years and have had hard use and show no signs of wear.
  • Leathery1
26 Jun 2014 07:25 #118652 by Leathery1
Replied by Leathery1 on topic Bushes trashed
Thanks guys. Full set of superpro bushes ordered. This is turning out to be an expensive MOT & service.
26 Jun 2014 09:32 #118668 by maverick
Replied by maverick on topic Bushes trashed
Leathery1 wrote: Thanks guys. Full set of superpro bushes ordered. This is turning out to be an expensive MOT & service.
Who ever said our hobby was cheap?
If you get the right parts, and fit them right they should last ... but everything wears out when off-roading!!
Jalapeño, IISY?
26 Jun 2014 11:52 #118678 by Rhinoman
Replied by Rhinoman on topic Bushes trashed
When you fitted the lift kit did you make sure that the suspension was settled before tightening all the bolts? if you don't do that then the bushes are under constant twist and can be twisted too far at full flex.
  • Leathery1
26 Jun 2014 21:44 #118733 by Leathery1
Rihnoman, didn't know that suspension should be settled in.
I am lazy so get a local mechanic to do my spanner work for me. He is really good, having built his own challenge trucks etc in the past, very knowledgable 4x4 mechanic and he enjoys working on the Jim, gets bored with too many landys, but he didn't mention bedding in the suspension following the lift. I will ask him about this.
Looking back, I probably went for stock bushes when I bought the lift as I didn't intend to make it a hard core off roader, but have done more than I anticipated so rubber bushes probably weren't up to the job. This stuff is addictive, you always do more than you intended (hence the winch and snorkel now going on!)
Lesson learnt. Buy the best bits you can afford but expect them not to last! LOL
Time to create page: 0.095 seconds
