gearbox cover I think is missing
- idiotmobil
24 Jun 2014 11:00 #118465
by idiotmobil
gearbox cover I think is missing was created by idiotmobil
I've been having trouble with week clutch. Slipping when in the muddy stuff looked under the Jimmy today cause I've noticed before there looks to be a cover missing can any one confirm this by picture
Would explain way I'm on 3rd clutch and lose power in mud etc as would go straight in there clog the lot up and lose power the after the grit would act like cutting compound
Attachment not found
24 Jun 2014 11:08 #118467
by Jezz
It's been fettled just a tad.
Replied by Jezz on topic gearbox cover I think is missing
Yep, There should be a tin plate cover there.
24 Jun 2014 11:10 #118468
by j999pre
Grey pick up Jimny
Replied by j999pre on topic gearbox cover I think is missing
I may have a spare
Grey pick up Jimny
- idiotmobil
24 Jun 2014 11:15 #118472
by idiotmobil
Replied by idiotmobil on topic gearbox cover I think is missing
I did think that each time I've done a clutch change just to forget full to sort it out hopefully I can slid one in with out the whole lot coming off
- idiotmobil
24 Jun 2014 11:49 #118478
by idiotmobil
If you have that would be great can you message over a price delivered to Southampton have you got any of the cable cover bits that's gone to
j999pre wrote: I may have a spare
24 Jun 2014 16:20 #118498
by j999pre
Grey pick up Jimny
I think I have both, I'll check tonight. You can fit the tin cover last, make sure the 10mm bolt holes are available and don't have sheared bolts in
Grey pick up Jimny
Time to create page: 0.103 seconds
