Panhard rods
  • rhys15
18 Jun 2014 21:20 #118169 by rhys15
Panhard rods was created by rhys15
Hi, i fitted new adjustable panhard rods tonight i got the back one on ok and ajusted it up and thats all good, fitted the front one and adjusted the same, so both the axles are in the middle but the steering wheel is half a turn out to the passenger side.
Do i need to slacken the nut on the steering box and move the arm a couple of splines to re-centre the steering wheel.
Cheers
  • Shep
18 Jun 2014 21:36 #118170 by Shep
Replied by Shep on topic Panhard rods
I got my steering wheel sitting right by adjusting the drag link ( steering box to knuckle)
18 Jun 2014 21:36 #118171 by Busta
Replied by Busta on topic Panhard rods
You need to adjust the drag link length by winding the ball-joint in or out.
  • Swifty
18 Jun 2014 22:03 #118172 by Swifty
Replied by Swifty on topic Panhard rods
I had the same issue and followed this guide.
www.bigjimny.com/index.php/component/con...110-steering-v15-301
Hope it helps
  • rhys15
19 Jun 2014 16:34 #118217 by rhys15
Replied by rhys15 on topic Panhard rods
Does adjusting thiw not make any difference to the steering lock??
19 Jun 2014 17:11 #118222 by Busta
Adjusting the drag arm doesn't. Leaving the wheel at the wrong angle or moving the steering arm on the box probably will.
Time to create page: 0.104 seconds
