Oil leak?
  • 2014Nathan
08 Jun 2014 12:10 #117371 by 2014Nathan
Oil leak? was created by 2014Nathan
Was fitting my wheels spacers earlier seen iv got a leak, engine oils okay so guessing gearbox gasket or something?
  • markyp2000
08 Jun 2014 16:15 #117383 by markyp2000
Replied by markyp2000 on topic Oil leak?
What engine is it cos on my single cam i had a leak in that area and it was the seal on the end of the cam shaft where the sensor is
  • 2014Nathan
08 Jun 2014 16:35 #117385 by 2014Nathan
Replied by 2014Nathan on topic Oil leak?
Err not sure of the engine code but 1999 my jimny is?
  • parriehunter
08 Jun 2014 23:35 #117437 by parriehunter
Replied by parriehunter on topic Oil leak?
Trying not to hijack this thread but i do also have a leak at the sensor on the back of the head on my G13BB.
What is involved in fixing this, is it and O-ring can you put the sensor on wrong etc?
Thanks
  • parriehunter
23 Jun 2014 00:26 #118402 by parriehunter
Over the weekend I was brave and took the cam sensor off, found that someone before me had tired to fix it as well but didn't put the gasket glue right round.
I was an easy three bolts to get off, cleaned all the old gasket glue and re did it. Now no more oil leaks at the back of head.
  • Wiltec17
23 Jun 2014 17:38 #118435 by Wiltec17
Replied by Wiltec17 on topic Oil leak?
I have a very similar leak, I assumed it was rear main, but after reading this it looks like il be resealing the cam sensor. Thanks for the heads up :)
Time to create page: 0.126 seconds
