alternator belt
  • rexthecat
07 Jun 2014 11:52 #117290 by rexthecat
alternator belt was created by rexthecat
Hi, can anyone give me some advice on fitting a drive belt on my 99 hardtop. Think what i need to do is put tension on from the alternator, kind of nip the bolt up and then use a breaker bar to lever the alternator and put tension on the belt. That sound about right, not done it before.
Cheers
07 Jun 2014 12:21 #117293 by facade
Replied by facade on topic alternator belt
That is substantially correct. Be very careful with the lever, that you are not levering something fragile that will break. (Or onto the back of the crank sensor)
Really you are simply applying tension and holding it whilst you do up the top adjuster bolt.
The tension is right when you can just about turn the belt 90 degrees in the middle of the longest run.
Time to create page: 0.084 seconds
