'Clunk' from nearside front when reversing.
  • JAGM
27 May 2014 12:22 #116441 by JAGM
Tried this on 'Chat' but got only one reply1 I have owned my 2005 VVT (completely unmodified) for almost a year. It has 27,000 miles on the clock and had one elderly lady owner. It is in immaculate condition and has been well-maintained. When reversing, with some steering-lock on, there is a gentle 'clunk' coming from the nearside / front area. It almost sounds like the noise that the vacuum hubs make when they are engaging (the 4WD is working perfectly, by the way). It has been like this since I bought it and it does not bother me too much, but I just wanted to know if it could be something that would need to be remedied in case it causes a bigger problem later on. The Kingpins and Bearings have recently been renewed and are 100%. Any ideas????
Regards,
JAGM.
PS Doesn't happen when reversing in a straight line!!
27 May 2014 15:02 #116451 by Halford
So did you get the tracking checked ?
  • darthloachie
27 May 2014 15:28 #116452 by darthloachie
Replied by darthloachie on topic 'Clunk' from nearside front when reversing.
is it a single clunk or a clunk clunk clunk
if its a single clunk have a look at the universal joints on the props to see if there is any play
also check the trackrod ends (theres four of them) for play
if its a clunk clunk clunk it could be a cv joint
  • GuardianAngel
27 May 2014 16:13 #116454 by GuardianAngel
Replied by GuardianAngel on topic 'Clunk' from nearside front when reversing.
Could also be heavily worn radius arm bushes, or elongated holes in the rear axle bracket where the radius arms bolt onto.
27 May 2014 17:09 #116457 by Halford
darthloachie wrote: is it a single clunk
think so
darthloachie wrote: check the trackrod ends (theres four of them) for play
that's where my money is,
if the tracking is out this makes it worse,
dips, when rolls off the tyre wall sipes and stresses the joints
so when reversing, clunks and groans like mine did before getting the tracking sorted,
even though I know that one of my ends is on its way out (split rubber), it no longer clunks since it was tracked
GauradianAngel has some good points, but for a 27k mile car it must have had some life
  • C-U-JIMNY
27 May 2014 21:41 #116481 by C-U-JIMNY
Replied by C-U-JIMNY on topic 'Clunk' from nearside front when reversing.
Check and see if the tyre is rubbing against anything if on full lock
Time to create page: 0.103 seconds
