o2 sensor check
  • 410shotgun
22 May 2014 18:33 #116032 by 410shotgun
o2 sensor check was created by 410shotgun
how can I check the 02 sensors out to see if they are working ?????
22 May 2014 18:45 #116033 by Rhinoman
Replied by Rhinoman on topic o2 sensor check
You really need to use a scan tool to see if the front sensor oscillates between around 0.1V and 0.9V with the engine fully warmed up. The rear should give a fairly stable voltage.
  • 410shotgun
22 May 2014 19:20 #116039 by 410shotgun
Replied by 410shotgun on topic o2 sensor check
ok I will scan it tomoz
what should the rear sensor be around
  • 410shotgun
05 Jun 2014 18:26 #117166 by 410shotgun
the rear sensor is reading 1.25v is this ok
05 Jun 2014 18:42 - 05 Jun 2014 18:43 #117168 by Rhinoman
That sounds high, what does it read with the engine off?
Last edit: 05 Jun 2014 18:43 by Rhinoman. Reason: corrected
  • 410shotgun
05 Jun 2014 19:19 #117174 by 410shotgun
I don't know I will check tomoz
Time to create page: 0.103 seconds
