o2 sensor check
- 410shotgun
12 years 5 months ago #116032
by 410shotgun
o2 sensor check was created by 410shotgun
how can I check the 02 sensors out to see if they are working ?????
12 years 5 months ago #116033
by Rhinoman
Replied by Rhinoman on topic o2 sensor check
You really need to use a scan tool to see if the front sensor oscillates between around 0.1V and 0.9V with the engine fully warmed up. The rear should give a fairly stable voltage.
- 410shotgun
12 years 5 months ago #116039
by 410shotgun
Replied by 410shotgun on topic o2 sensor check
ok I will scan it tomoz
what should the rear sensor be around
- 410shotgun
12 years 5 months ago #117166
by 410shotgun
the rear sensor is reading 1.25v is this ok
12 years 5 months ago - 12 years 5 months ago #117168
by Rhinoman
That sounds high, what does it read with the engine off?
Last edit: 12 years 5 months ago by Rhinoman. Reason: corrected
- 410shotgun
12 years 5 months ago #117174
by 410shotgun
I don't know I will check tomoz
Time to create page: 0.089 seconds
