Replacing bettery
- RobT
20 May 2014 07:34 #115796
by RobT
Replacing bettery was created by RobT
Hi guys, quick question. (It's about 20 years since I last did anything other than top up washer fluid under a bonet) I need a new battery, if I fit it myself am I going to run into trouble with things like key fobs and radio codes?
- steffan
20 May 2014 07:50 #115797
by steffan
Replied by steffan on topic Replacing bettery
It's relatively simple job really I don't now about radio codes as mine has an aftermarket radio in the key fob shouldn't need messing around with as mine had always worked after the battery has been off
- RobT
20 May 2014 09:49 #115808
by RobT
Thanks Steffan, I've ordered one and will have a go.
Rob.
Replied by RobT on topic Replacing bettery
steffan wrote: It's relatively simple job really I don't now about radio codes as mine has an aftermarket radio in the key fob shouldn't need messing around with as mine had always worked after the battery has been off
Rob.
- RobT
20 May 2014 14:40 #115831
by RobT
Thanks Job done, no problems. Tip from youtube disconnect the negative first and reconnect it last, in case your spanner hits the chassis while undoing the positive. Quite hard do do in the Jimny with the battery location but worth taking the precaution I thought.
Rob.
Rob.
Time to create page: 0.086 seconds
