Annoying metallic rattle
- Nelson83
14 May 2014 15:50 #115218
by Nelson83
Annoying metallic rattle was created by Nelson83
My trucks started to develop an annoying metallic rattle - sounds very similar to those spoke flickers you had a kid on your bike. I've had it serviced this past 4 weeks and the garage said they could see anything obvious, and they stripped the brakes during the service and adjusted everything back to normal. Its definitely not the heat shield on the cat as i dont have one with my cat.
Initial thoughts were the brakes so I've stripped the brakes again today, taken it for a run and it appears back. It starts at about 30mph and disappears, but i have heard it happening past 50mph. Wheel bearings seem ok, no knocking and no play when pushed and pulled, the king pins are the same, no play and no leaks.
Can't get it to rattle in reverse and at slow speeds there no sound, just when driving along. No pattern, it suddenly appears and disappears. My next thoughts are turning to the clutch and the clutch bearings - ive done over 130k and as far as im aware its still the original clutch (ive put 90k on myself and have run 235/75/15s for the last 18months/ 2years with no problems) or possibly a rear prop (the centre prop was replaced two weeks ago) as the when i lie underneath and shake everything, theres a metallic sound coming from that. When you dip the clutch and change gear, if its making the noise it goes but often reappears.
Suggestions on a postcard plese
14 May 2014 15:54 #115219
Replied by mlines on topic Annoying metallic rattle
Universal joint?
If you have the time, remove the rear prop and drive in 4wd (ie. front wheel drive) and see what happens
- Nelson83
14 May 2014 15:58 #115220
by Nelson83
Replied by Nelson83 on topic Annoying metallic rattle
It has crossed my mind that the centre prop UJ failing may have knackered the rear prop - there was plenty of movement in the transfer box before i swapped props. The mounts for the transfer box are fine - checked them already.
- Basketcase
14 May 2014 16:37 #115225
by Basketcase
Replied by Basketcase on topic Annoying metallic rattle
We had a metallic rattle on ours turns out it was the prop from the transfer box to the rear axle but also have a stone in the bell housing that somtimes gets stuck somewhere so rattle goes away for a bit
- marko
16 May 2014 23:33 #115471
by marko
Replied by marko on topic Annoying metallic rattle
My jimny sounded like that after months of scratching my head I found the steel dust cover over the diff came loose and would spin round the prop then when you stopped it went then would come back every now and then or you hit a bump . It could be that
- Docmartin4x4
17 May 2014 09:30 #115519
by Docmartin4x4
Replied by Docmartin4x4 on topic Annoying metallic rattle
I had a metalic rattle on mine which drove me absolutely beserk!!!! Thought it might have been the heat sheild on the exhaust, so ripped it off....still rattled, thought then it might be the cat. breaking up so i took the exhaust off to check and I found a bolt inside the exhaust!!!! I know that does not help you much but I thought you would like to hear the story!
Time to create page: 0.096 seconds
