Dual Battery System advice
  • jtayl153
12 years 6 months ago #115081 by jtayl153
Dual Battery System advice was created by jtayl153
I'm setting up a dual battery system in my Jimny. Need some advice.
I have A/C and ABS and need a tray for the battery to sit on, and nowhere (that I've found, or that my 4x4 mod guys have found) make on for a jimny with ABS.
Here's a standard engine bay (not mine)
Here's what I want to do:
Battery tray is mounted between ABS and front. Window washer and radiator overflow bottles mounted to the tray.
Thoughts?
Also, as far as the batteries themselves go, I'll be keeping my standard battery for start up, and ill use an Optima D3478 (yellow top) as my Aux battery. Should be able to run a winch and a fridge!
  • jonesyba420
12 years 6 months ago #115084 by jonesyba420
Replied by jonesyba420 on topic Dual Battery System advice
Custom make a tray yourself or get someone to fab one for you, is there enough room between the abs module thing near the bulkhead and the washer bottle?I dont have abs so cant look. Looks tight from the pic, id look at making a tray that relocates the washer bottle in line with the rad expansion chamber and mounts the battery where the washer bottle is if that makes sense.
  • jtayl153
12 years 6 months ago #115087 by jtayl153
Replied by jtayl153 on topic Dual Battery System advice
thats what I meant only I don't english too good at 1am ;)
Yeah, I've measured it, there's enough room for a battery to mount where the washer bottle is, and I'd then mount the washer bottle and radiator expansion chamber to the tray.
  • jonesyba420
12 years 6 months ago #115091 by jonesyba420
I believe jimnybits do a tray like what your after but not sure if its compatible with ABS.
12 years 6 months ago #115093 by maverick
Replied by maverick on topic Dual Battery System advice
I also have a ABS Jimny and originally wanted two batteries, like on my old SJ that had two batteries, but there really is not a lot of room.
So, I didn't fit another battery, and to be quite honest i haven't suffered... as yet!! Even using/abusing the winch a few weeks ago at a Punch Hunt.
If I was pushed to fit it, then the i think that i would move the washer bottle backwards towards the ABS unit/pipes and then fashion a battery tray in the space closer to the headlight - the only problem I anticipate, is will there be enough room (height) for the 2nd battery to miss the bonnet?
I have also heard that Russ (JimnyBits) has done something, but I would like to see his engine bay to understand/see what he has done there ...
Good Luck, and if you do something I'd be interested to see it :)
Jalapeño, IISY?
  • Bits4Vits
12 years 6 months ago - 12 years 6 months ago #115100 by Bits4Vits
Last edit: 12 years 6 months ago by Bits4Vits.
Time to create page: 0.099 seconds
