Wheel Spacers
  • minare
12 years 6 months ago #114466 by minare
Wheel Spacers was created by minare
Hey all,
i have the jimny bits 3" lift + jimnybits front radius arms + 3" trailmaster comfort +215/75/15 bf km2 on stock alloy wheels
i use the 25mm spacers.
heard on the forum that there is problems with 32mm spacers, someone say that he change bearings 3 times in the past 18 monthes.. plus king pins bearings.
what is your experience with stock wheel and 32mm wheel spacing?
thanks all
Guy
12 years 6 months ago #114479 by maverick
Replied by maverick on topic Wheel Spacers
Ask yourself this, were the Jimny bearings designed to have 32mm wider on each corner ... Me thinks the answer is NO!
I have had 32mm Spacers on my Jimny for last 10yrs, and YES bearings do wear out (maybe once per year), but the extra width and stability you have for that extra gain in height is well worth it!.
Jalapeño, IISY?
  • Tommo
12 years 6 months ago #114526 by Tommo
Replied by Tommo on topic Wheel Spacers
I've had my 32mm spacers on and off, mainly on for every day use!
For about 3 years and never had a problem
  • steffan
12 years 6 months ago #114543 by steffan
Replied by steffan on topic Wheel Spacers
I had 32mm spacers on with off set wheels and a month later a bearing went so thought oh it might a been on it's way out anyway so changed it then within a week the opposite side went and thought oh they might of been done at the same time so did that one went green laneing a week later and hay presto on the way home a wheel bearing went so it was good by spacers and guess what they have been fine ever since don't do it to yourself
  • minare
12 years 6 months ago #114548 by minare
Replied by minare on topic Wheel Spacers
Hey Steffan,
what was the offset of your rims?
12 years 6 months ago #114601 by maverick
steffan wrote: I had 32mm spacers on with off set wheels and a month later a bearing went so thought oh it might a been on it's way out anyway so changed it then within a week the opposite side went and thought oh they might of been done at the same time so did that one went green laneing a week later and hay presto on the way home a wheel bearing went so it was good by spacers and guess what they have been fine ever since don't do it to yourself
What was the point with spacers with offset wheels - no wonder your bearings gave up!
IMHO, its EITHER spacers OR Offset Wheels.
Jalapeño, IISY?
