Prop spacer
  • Docmartin4x4
12 years 6 months ago #114420 by Docmartin4x4
Prop spacer was created by Docmartin4x4
on a 3" lift, I take it a prop spacer is required for front propshaft.......what about the rear?
Mart
12 years 6 months ago #114430 by kirkynut
Replied by kirkynut on topic Prop spacer
No I don't think it's needed. Mine has been lifted 3" in all the time I've owned it without issue.
Why do you think you need one?
The following user(s) said Thank You: Docmartin4x4
  • Docmartin4x4
12 years 6 months ago #114464 by Docmartin4x4
Replied by Docmartin4x4 on topic Prop spacer
I just thought as one was needed at the front you would need one for the rear also.
Mart
  • Swifty
12 years 6 months ago #114465 by Swifty
Replied by Swifty on topic Prop spacer
On the standard transfer box the 3" lift on mine was fine without any prop spacers. I had to add a 1/2 spacer on the SJ mini prop with a rocklobster as it was a little stretched. Not sure which you are running but just check them to make sure they aren't hard up or stretched, ;-)
12 years 6 months ago #114480 by maverick
Replied by maverick on topic Prop spacer
i have a 3inch Spring Lift and an SJ Transfer Box - I don't have any transfer box or prop spacer(s).
Jalapeño, IISY?
  • Tommo
12 years 6 months ago #114525 by Tommo
Replied by Tommo on topic Prop spacer
25mm ora spacer I've got on 3" lift
I think my mate dan ran his lift with out the spacer and it f***** it up
That's what he said to me any way, it doesn't hurt
To have a a spacer, you may be able todo with out but I'm
Not sure
Time to create page: 0.139 seconds
